So this morning a couple of jiffy bags arrived in the post which can only mean one thing....... eBay goodies!!!!
So I set to work installing the new side stripes to replace the worn scuffed and generally tatty old ones.
I took the old ones off with the aid of a hot air gun and razor blade then cleaned up the sides with brake cleaner and a rag before applying the new strips.
Second job of the day was to install the LED voltmeter.
My old set up consisted of a massive analogue voltmeter a 12v socket robbed from a scrap car, an old pod back off a dead pod and some 18mm scrap mdf.
I decided to neaten up the dash so sawn off the triangular bottom piece that housed the 12v outlet and voltmeter and cut it flush with the pod back, then with a bit of marking out drilling and cutting with a hacksaw blade and a razor blade I made a new home for the LED meter a bit of soldering and heat shrinking saw it installed and working.
(https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-ash4/1004031_10151517143286623_881438752_n.jpg)
(https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash4/1044657_10151517492666623_1028962872_n.jpg)
Looking good
So today the post lady handed me this....
(https://lh5.googleusercontent.com/-YkmYPREhSy0/UdKrh8yUl8I/AAAAAAAABfs/_2TN-12Dh80/w448-h796-no/DSC_0336.jpg)
So I removed the knobbly tyre and replaced it with the City jet that was on the original c5 wheel....
(https://lh3.googleusercontent.com/-VM-w-WkgyT4/UdKukPZSm0I/AAAAAAAABgE/wq9ZDXARaA8/w958-h539-no/DSC_0337.jpg)
Then I had to stretch the front forks a little to accept the new wheel....
(https://lh5.googleusercontent.com/-urnXrQuDzMQ/UdLqEE_c6KI/AAAAAAAABgc/edgQ2n4XznA/w958-h539-no/DSC_0338.jpg)
Which then allowed me to fit my nice new wheel!
(https://lh5.googleusercontent.com/-I-HKxpjEH1E/UdLubKco3jI/AAAAAAAABhM/bxl44U9LMPo/w958-h539-no/DSC_0341.jpg)
(https://lh3.googleusercontent.com/-WxbRg5QnsXo/UdLug3kesLI/AAAAAAAABhY/hv6EWRBnsIM/w448-h796-no/DSC_0342.jpg)
..that colour suits a c5 better than the "hot pink" wheel I once had fitted.. :D
