Hi, Can anyone advise where I can get a replacement Motor relay, I have power coming into the board from the switch & I have tested the motor direct off a battery, but I have no click coming from the relay, can I just use 1 off a car?
Hi there if you have tested the relay and it damaged then you could use one from a car but try and get one rated at 70amp ...Also you could take the old one out of the plastic case and try to fit the new one in ...Bye Chas
