C5 Help => C5 Support => Topic started by: dantheref on 25, September, 2013 - 20:33:26
Title: Lights!
Post by: dantheref on 25, September, 2013 - 20:33:26
My lights dont work, Can anyone guide me to which wires are for the lighting and any other possible faults?
Title: Re: Lights!
Post by: radiomarty on 26, September, 2013 - 10:26:20
The main issue with lighting is loose connection of the fuses in the control box - give them a wiggle and see if the lights come on - chec the connections at the back of the switch also - Marty
Title: Re: Lights!
Post by: dansretropod on 26, September, 2013 - 18:19:16
Yep, the fuses are always a good place to start.  If you're using the original bulbs I'd switch to using the low energy LED bulbs you can get off ebay for £2.50.
Title: Re: Lights!
Post by: rekooh99 on 27, September, 2013 - 07:47:25
You can also get the led bulbs from the c5owners forum for the same sort of price.
Title: Re: Lights!
Post by: dantheref on 30, September, 2013 - 17:09:36
Thanks for all your advice all working now, with LED bulbs on the way!
