Nearing the end of the restoration on my c5. Put a c5 alive wiring kit on but didn't relies that you need a pod to make it run. So does anyone has working one for sale :)
Hi you don't need a pod to make the C5 go but you will not get any indication of battery voltage and current being used .But you could connect the temp cut out ...to the wiring kit ..Also you could fit a volt meter .(That is if you know how to do it ) .
Hi, I have a pod for sale, £60 delivered, just need to fully test it before I sell,
Hi chas How do you get it to work without a pod. The lights come on but when you press the button nothing happens Regards Alex
Have found a pod now :)
