well I fit a cycle computer and set off to work, I check the calibration with a satnav and its spot on.
Then it chucks it down with rain, so much that the pod starts beeping - even tho the battery is fine, then it starts to go even when I dont press the go button.
I get to work, and the lighting has knocked the powe out, so i was on time even tho I was late - lol
I take the pod off to check for water ingress, only to find its fine, I check the control box and cant see anything wet, so I put it back together and find the pod wont light up. Turns out in my haste I pulled wire 1 from the pod connector.
I set off home at 10pm only to find my front light has blown - but even tho the pod did not light up the c5 worked perfectly.
There is a god - lol
Glad you made it back home okay mate, will you be able to fix the pod wire ?
There's no stopping your C5 !!!! - glad you got home safely. :D :D
Thanx guys, yes I think I can fix it. It will have to wait tho as I have pulled my back out - lol
I'm on the TENS machine - but will recover.
Quote from: Umpa on 08, July, 2009 - 10:42:23
ouch...know how you feel mate. Dodgy back is no fun at all :-\
