C5 Help => C5 Support => Topic started by: radiomarty on 23, September, 2009 - 20:59:45
Title: Un- even wear on drive wheel washer
Post by: radiomarty on 23, September, 2009 - 20:59:45
Hi - folks I was playing with Matt's C5 today and noticed that when I removed the drive wheel there are two metal washers that sit against the drive gear (the plastic wheel driven by the belt) One of these washers has become almost oval in shape and although two washers are fitted there is still about 4 - 5mm movement of the drive gear. Picture shows the washers in place and the gap on the end of he axle prior to fitting the wheel. Also noted some slight side to side movement in the chain sprocket on the rear axle when turning the pedals. Any idea what might be causing the wear in the washer ?
(http://i920.photobucket.com/albums/ad49/radiomarty/DSC01109.jpg)
Title: Re: Un- even wear on drive wheel washer
Post by: Karl on 24, September, 2009 - 12:41:33
Only a suggestion, but I dont think you've got enough washers there - I always use enough to "fill the gap" so to speak
It might be that the "oval" washer has been left with enough space to be able to move around, causing it to wear ?
There is a similar thread here ;
Post by: Retro Andy on 24, September, 2009 - 13:36:59
I was thinking the same as Karl.
Post by: radiomarty on 24, September, 2009 - 15:45:16
Thanks guy's will put more washers - only had the two because that's how it was when I got it but I can see what your saying.
Post by: Umpa on 25, September, 2009 - 06:06:42
If you get some will you let me know where from coz I c
need a few too.
Post by: radiomarty on 25, September, 2009 - 20:32:47
No probs Umpa as soon as I find some I'll post some to you.
