Brand New (Some Original)Some used Sinclair C5 Spare Parts for Sale....Now!!
Started by C5 ENTHUSIAST + RESTORER, 22, April, 2010 - 16:37:57
Hi Chas - many thanks - payment sent - have managed to make some mods to the tensioners to get round the problem with them.
rekooh99
Hi Chas wondered if you have any chain tensioners as I need one ,if you do have one how much? Thanks.
rekooh99
Hi there I only have an original chain tensioner + boot clips for sale if you are interested let me know ..my email address is Snarski4@aol.com       Bye Chas
#64
Hi all just had a new gearbox insert made up but not tested yet but looking good it will be a lot stronger that the original as there will be 4 small gears going round instead or three ..Thanks to Simon for suggesting that I have a go at making one with 4 gears ...
I will post more info as to how it runs ..But first have to have the drive teeth fitted ..
looks good, it will be very interesting to see if it copes better or not   :)
Hi there Lance the new gearbox will not increse the speed or the torque but what it will do is to spread the load on the small gears more  evenly instead of 33% of the load on each gear it will be down to 25%  and hopefully  make the gearbox stronger especially when the C5 has been converted to run on 24 volts . But as yet I have not tested it out ....
Pep
Hi Chas
I would like to order the following items
#10 pod washers x 2
#19 boot clips x 4
# 45 battery straps x 2
I also need a boot lock assembly I have a key and barrel to fit, if you have one
Please let me know the price and how best to pay
Thanks Pep :)
Hi there Pep not sure what you want regarding the boot lock ...I do have the other items you wamt just let me know about the boot lock ..
Pep
Hi Chas, I only have a hole in my boot, ie no lock at all, I do have however two battery keyswitches which I have had keys made to fit and was wondering if they are interchangable,
Thanks Pep
Hi there is a way but it's not easy ...I have just made one fit a new key and it works great ....
Pep
Hi Chas, If you still have the parts I need could you please let me know how much and how to pay, thanks Pep  :)
