Indicator,s now working help
Started by marcdonnelly, 17, May, 2010 - 09:20:18
marcdonnelly
Can anyone give me some advice my lastest c5 came with indicators fitted but i cant get them working is there any common faults? i thought it may be the sealed flasher unit but tested another flasher unit on the c5 off my spare set and still no flashing?.can the flasher unit be replaced by a non orginal.
Have you got power going to them, if you have tried another flasher that is known to work, then its not that thats the problem (i think a normal 12 volt flasher should work as a replacement)
You will need to follow the wiring back to where it gets it feed, check if you have power at the switch, its process of illimination. There is not that much that can go wrong really with these.
Have a look in the un official handbook , it shows the whole circuit for the indicators.
Sounds like a lack of power going to them  :-[
marcdonnelly
Thanks john just found a honda c70 12.8 volts 60 watt 2 pin flasher unit on ebay looks like its a perfect replacement £8.00 delivered, think i will order it i will let you know the results soon.
No problem ...
I am sure you will get them sorted, i dream of owning a set of C5 indicators ....   :-[
John    ;D
marcdonnelly
Must agree john they do look better with the indicators on,update on my second c5 just now putting her all back together with mr cubbit ok im making tea and doing odd jobs will update later how we get on.
plumber
Undate on c5... 2 now called FLASH me and neil after 4 hours and ten cups of tea she
is fixed and good,  thats what  a plumber says( can i trust him) , thats what england was built on (lots of tea). work done tonight is tyres and tubes,front brake blokes,changed handle bars to correct position, (think mine was left hand drive)lol.....new belt , new motor , new drive belt and orignal key switch,fixed indicators ( new name FLASH I LOVE THEM WORKING INDICATORS) and stripped done front wheel bearing and cleaned regreased and made good ps rear brakes and bearing,s also....Im happy but the good friend now says i owe him a pint i thought a half would do the trick. any thoughts on this????
