had a try with one of these betteries
Started by marra, 31, August, 2010 - 19:07:16
Quote from: Rickvalet on  22, September, 2010  - 16:59:04
Hi, I splashed out and bought a Ping battery off Ebay. Ping builds them to your spec and they are Lifepo4.
Battery spec
Lifepo4
12v
40 Ah
Weight 5kg!!!!
The Results?
Well I get about thirty miles from a charge and you really notice the 10kg weight saving. I Pulled the guts out of the Oldham battery and put the new one inside so it looks original and retains key.
These new Ping batteries really are superb.They cost £350, but will outlast the life of a lead acid more than eight times over.    :)
A superb effort mate, and very impressive.
I've always fancied a dabble with lithium based batteries but never had the spare cash to justify it.
It's good to see them actually being used, rather than just in theory  :D Are they more fragile regards charging ?
alexbromo
A cluster of four of these Foxx 3.2v cells: http://cgi.ebay.it/Foxx-Power-LiFePo4-40a-Cell-/140350983908?pt=LH_DefaultDomain_0&hash=item20ad920ee4
capacity: 40Ah
weight: 6.5 Kg
price: £142
it appears a lot more attractive.  ::)
Alex Bromo
Quote from: coverman on  01, September, 2010  - 08:57:30
The advertised weight for the battery is obviously prior to charging.It weighs significantly more when full of electricity!!!!.
lol that made me laugh :)
frankev
I use a Marine semi traction battery 105 Amps, the specs say you can empty it to 80% of its load many of times, it is about 28 kilo and so big that I sometimes hit the back of my feet against it when I try to pedal  :D
45 miles I already did once, no problemo. Still had 11.50 volts on the meter during the end of the ride, power on, that was about the same when I started. price about 100 pounds.
I'm going to swap it for a 80 amps version because it is about an inch shorter. And obviously shorter.  ;)
There is a 55 amps version also that costs 55 pounds weights about 16 kilo.
Going to try that one for my second C5 that currently drives on a 80amps car battery. Car battery goes faster when its full but drops speed gradually. And they tell me that its bad to empty it more then 50%. Kills the battery.
Frank
