fully tested pod problem
Started by marcdonnelly, 06, October, 2010 - 20:49:34
marcdonnelly
Can anyone help me solve this problem just brought a c5 minus the pod i then put my tested pod by chas on it that works 100% and everything was perfect but then after about 10 minutes i noticed that the lights that go up and down to indacate speed and going up hills etc etc had stopped working and even going down a hill fast it still showed red on the pod.I  guessing theres a fault in the control box and wondered if anyone could tell me what diode was at fault thanks marc.
Hi it is most likely to be the op amp (358) or one of the transistors (poss t3) in the control box
marcdonnelly
Thanks for that i will ask plumber to have a look for me when he gets back of his hols ..I have a spare control box i will take it apart and try and find where the 2 items you mentioned are..
marcdonnelly
thanks can i buy those 2 from maplins etc etc and does you or anyone know the codes to order thanks again.
Both available at Maplins, don't have the codes at present.
If you change the Op amp, i find it a good idea to fit a socket to the PCB then plug the Op amp into it, just makes it easier to replace if you need to change it in the future.
Hey Plod great minds think alike I always do that too  :)
aladds
That's what I did with mine as well :-)
