where is located this item ?
Started by alexbromo, 01, November, 2010 - 17:44:41
alexbromo
I completely forgot where is located this detail:
under the motor ? I'm not able to find a location ...
Alex Bromo
MattC5
alexbromo
Ah, yes ... thank you !!!  :D
Is not very clear for me the real purpose of this piece ... has it some role in motor alignment ?
Alex Bromo
It stops the Motor/ Gearbox falling off the plastic fence it sits on, this tends to bend and the gearbox falls off and then off comes your belt and then your problems start.
This was always a problem and this was the answer to stop it, you can get the same effect with a large cable tie to stop the fence flexing.
alexbromo
Thank you all for explanation.
My C5 would not make sense whitout this forum ...  :)
Alex Bromo
..this is the link to how we use the cable tie to do the same job as the metal bracket;
http://c5alive.co.uk/forum/index.php?topic=1181.0
...as Plod says, it keeps the motor/gearbox properly positioned in its mounting.
