Fitting a front disk brake ...
Started by alexbromo, 07, November, 2010 - 22:20:08
frankev
My C5's stop with the original brakes as well. I will try one with an anchor for emergency stops  ;)
I have disk brakes on the front wheel of my bicycle. If I use them I flip over the front wheel. Did happen twice  :'(
alexbromo
Quote from: frankev on  07, December, 2010  - 13:06:51
Effectively a disk brake is a very strong unit for C5 quotas.
If a normal disk brake is capable to instantly block a 26" bycicle wheel, scared to imagine what it can do on a 12" wheel, where the results of the torque applied by the rotor is virtually double ! In fact i seen that on my C5 also a very little force on the brake lever results in a very strong braking.
I guess the real risk to destroy the little plastic wheel in case of emergency braking ...  :)
Alex Bromo
techytype
sorry, but i've been busy,
photo's that show what i mean in the link, the rota is a 180mm, but will be shortly changed for a 140mm (received today) to beter allow wheel cowl to be fitted.
http://i1220.photobucket.com/albums/dd454/techetype/Sinclair%20C5/C5FrontBrakecloseupofRotalockingBoltbolt.jpg
Alan
techytype
Quote from: alexbromo on  07, December, 2010  - 14:07:57
original brake is very hit an miss affair, slightly damp and very little effect. disk brake will be like car servo brakes, but if your heavy on the lever the C5 will skid before it stands on it's nose - hopefully  :o
once i've done the back brake perhaps an ABS system will be next?  ;D ;D ;D
Alan
alexbromo
Quote from: techytype on  07, December, 2010  - 20:00:50
I also chose the 140mm rotor (the littlest bycicles available) to have sufficent room to reinstall the original plastic cover, moreover i had to cut a little piece on the top of the right cover because the cable and clamp's arm slighty interfered on it.
Alex Bromo
techytype
hi alex,
been really good to have someone to compare and bounce idea's off,
i'm part way through mounting the bracket for the brake, mounting mine behind the fork (motor side), the bracket is 'pushing' against the fork when applied, meas it takes less strain and can be a lot thinner.
just for 'jigging' i've used a very simple 'L' bracket for the upper fixing bolt, drilled right though the fork, then nut and bolted bracket to secure it.
i will be making a simple straight strap, with a hole to go on the axle (between wheel and fork), that will then be bolted onto the lower brake fixing.
when happy i'll add photos,i'm lucky as i have a spare chassis and forks with steering rod
regs
Alan
frankev
Quote from: techytype on  07, December, 2010  - 20:08:38
Alan
this ABS thingy, I go check to that out. If it works on a car with 12 volts it can be useful for a sinclair C5 as well.  :P
alexbromo
Quote from: techytype on  08, December, 2010  - 13:19:09
hi alex,
regs
Alan
Very interesting solution Alan !  ;)
What kind of material have you used to build the bracket ?
Alex Bromo
techytype
So far just proto typing on some spare forks,
I'm attaching upper mount with a simple  L bracket, drilling through the fork leg from to back, lower hole will be a straight strap either to go over axle between wheel and fork, or bolted on the inner 'face' of the leg.
As my caliper is dragged toward the fork in use, it allows thinner material, if one should break or i loose a bolt then it will be stopped by the fork, sort of extra safety designed in.
Been working on designs for rear break, that will be IMHO very radical. Si watch this space ;).
Alan
quasimodo
Love this! Nicely done!
I will fit mine with a disc-brake too. Will probably need some good stopping power with my new 750W-24V motor fitted.
Greetz
www.sinclairc5.nl
techytype
Been all stop due to Xmas season and snow, but hope to get back on ti it this weekend, if my son don't need help to move out that is (waiting for date from agents).
Alan
Wow that motor looks the business  :)
techytype
Quote from: quasimodo on  05, January, 2011  - 20:20:17
Greetz
www.sinclairc5.nl
Pictures and details please (so we can lech then :) ).
Regs
Alan
quasimodo
Of course I will put all details on my blog.
I hope my frame will be ready tomorrow, so I can start the build.
First steps:
- Mount the motor
- New Ball Bearing for the steering and the front fork
- Install necessary wiring and computer.
- Upload Pictures !!!
frankev
Hi Quasimodo,
Did you read the reply I left, concerning the Dutch law for E-Bikes on your topic about your 750watts 24v project topic. I don't aspect much trouble for you unless you start doing wheelies on the road.  :D :D
