Bearing issues
Started by ScubaChris, 31, March, 2011 - 21:42:35
ScubaChris
Just wondering if anyone can offer a little advice on a couple of issues here.
1) Just finished stripping, cleaning and greasing the front wheel hub & bearings. The small bearings (in plastic cages) looked ok but when I spin the wheel it runs pretty 'lumpy' as if the bearings are worn. Are replacements fairly easy to get hold of?
2) I tried to replace the uni-directional roller bearing in my main drive cog (the big white plastic cog). One of the rollers is missing and I have a new bearing to go in. I tried all sorts to get the old bearing out but it seems stuck fast and I can't get too heavy with it as there are a few worrying looking cracks in the cog which I don't want to make worse. Is there any special technique to getting them out? It looks like there's a wide bearing in between 2 narrower ones. I'm trying to replace the wide one.
Thanks!
C.
Chas (aka "c5 enthusiast & restorer") might be your man for both these queries , if he doesn't pick up on this topic I'd send him an email  :)
Although I've never had a snag with either of these so far, I'd also be interested in the reply  :)
Hi there First of all the bearings in the front wheel They can be replaced as long as you use the plastic cage .
I can send you some bearings to replace the old ones ..Just email me your address.
Regarding the roller bearings in the large cog as far as I know the only way is to tap them out but as you said there are small cracks on the cog  (most of the cogs I`v seen have all got the same cracks)  So it`s up to you to carefulul ...By Chas
ScubaChris
#3
That's great Chas, I've just sent you an email.  :)
Think I'll leave the old bearing in the drive cog and hope for the best. Knowing my luck I'll snap the cog in half and then have to find a replacement.  ;)
C.
