Author Topic: bearing  (Read 3567 times)
wubbert
bearing
« on: 19, June, 2011 - 21:58:40 »
Hello,
I'm busy to fix my Sinclair....after the spline was worn out i wanted to change the rear axle (thnx for that one frankev  8))
but when i removed The motor mount all the needles from the bearing came out  :o the cage was totally twisted  >:(  i looked at the site of SKF and INA but the size of the "Drawn cup needle roller bearings with open closed ends" doesn't match as Wat the Sinclair got  ???
does anybody know the part number or where i can buy it in Holland???
for the visual people...its this bearing :
Re: bearing
« Reply #1 on: 19, June, 2011 - 22:40:11 »
This topic may help, although it relates to the bearing fitted inside the large white drive cog there is also mention of the motor mount bearing and a picture giving the part numbers.
http://c5alive.co.uk/forum/index.php?topic=1859.0
Failing that, I'm sure Chas will be along soon to help  ;D
ScubaChris
Re: bearing
« Reply #2 on: 20, June, 2011 - 10:16:44 »
Hey, I recognise that photo!  :o ;)
C.
wubbert
Re: bearing
« Reply #3 on: 20, June, 2011 - 11:27:31 »
C.
yep, i stole it  ;) you're not going to seu me right??? 8)
But is the INA HK2016 the right bearing for the axle??
« Last Edit: 20, June, 2011 - 11:29:24 by wubbert »
ScubaChris
Re: bearing
« Reply #4 on: 20, June, 2011 - 14:35:50 »
C.
Lol... No I won't sue you. It's nice to have my photography admired. Here's another picture you might find useful:
As you can see, the INA HK2016 is exactly right. I'm not sure if I have one spare but I will check tonight when I get home from work.
Chris.
wubbert
Re: bearing
« Reply #5 on: 20, June, 2011 - 15:01:52 »
I already orderd it at my bearing shop...
I have 60% discount over there...
Thnx for the part number
Offline jockywilson11
Re: bearing
« Reply #6 on: 24, June, 2011 - 23:56:21 »
INA HK2016 Try a quick google search
