Author Topic: A novices 24v question  (Read 2114 times)
Offline minidaz
  • Battery level: 6
« on: 07, July, 2011 - 19:20:01 »
Im thinking of getting another cheap (ish ) C5 to tinker with and try out 24v
As i've never done anything with C5 electrics, is the 24v conversion a simple one ?
Is it a case of just fitting a controller inline between a pair of batteries and motor ( similar to what Marty is using on Goldmember ) , and then adding a twist grip , or is there a bit more to it ? ( told you i'm a novice  :D :D ). I understand the pod would become redundant.
My plan is to try to do it on a budget, and see how i get on .... atleast i've got nearly a year until the next AER  :D
Daz
wubbert
Re: A novices 24v question
« Reply #1 on: 07, July, 2011 - 20:44:48 »
i just converted mine to 24v if you take a basic controller you
Will blown you're engine...because it is doing to many amps...
or you will have to less power...
i took a basic controller and modified it a bit..
so it does not put more then 29amps on the motor.
doing some tests with it and do the "achterhoek-run"
after that you can buy it from me with a throttle for around 50,- pounds
excl shipping (from the netherlands)
if anyone is interested i will hear it!  8)
Offline minidaz
  • Battery level: 6
« Reply #2 on: 07, July, 2011 - 22:41:17 »
You'll have to keep us all posted on how your testing goes  :)
Daz
Jonny
« Reply #3 on: 07, July, 2011 - 23:56:19 »
so a simple controller with some sort of current limiter?
