controller cooler
Started by ogb, 17, August, 2008 - 22:19:16
ogb
My controller was a little bit warm so I did mount an old CPU cooler on is and it works fine
blabblub
What do you reckon is best
1 Suck the heat away
or
2 Blow the heat away ?
ogb
The standard construction of the cooler is to blow the air over the cooler (and than when it was still in the PC over the processor) over the controller
I think the IT boys did some tests with it and this was the best result
Main issue is to use cooling pasta in-between the cooler and the controller to get the best heat transmission from the controller to the coolerblock
jomac
Quote from: blabblub on  17, August, 2008  - 22:56:02
or
Best choice is to blow the heat away, if you suck the heat away the fan will get warm and have its lifespan shortened
ogb
the fan had his lifespan long ago in an old pc en worked for more than 5 years 24hours a day in an atmosphere of 70-90 degrees so what is the problem with mixed air of -ish ..... 40 degrees ???
will it last till my c5 is 50 years      :P      2035
we've done the same thing to cool the 24v controller on "Voodoo" - works a treat  :)
aandu
Wonderful idea... I will remind myself to go hunting for CPU fans in the local tip!  ;D
jomac
Quote from: ogb on  18, August, 2008  - 16:53:38
Sorry i was in techie/newbie mode if that makes sense, but seriously, find the cause of the heat and why, what is getting hot, if its a controller and hidden in the boot, it wont get much air, move it into an airstream, the extra fan will reduce your range, not by much but it will.
What are the chracteristics of your controller, do you have a spec sheet?
ogb
#8
specs
浙江翼昀科技有限公司是以专业生产电动车控制器、充电器为主的企业,创建于1998年,先后自主开发电动车控制器十大系列(九十余个品种),充电器五大系列(二十余个品种);产品系列主要包括有刷、无刷控制器,充电器以及各种配套电器产品,广泛用于电动车、电动摩托车、三轮/四轮车、电动滑板车、电动玩具等系列电动产品。我们产品进入市场至今,已成为众多海外采购生产商指定配套产品。
  我公司坐落在中国五金之都--浙江永康,现拥有现代化厂房和一流的生产制造检测实验设备,具有完善的产品监控系统。多年的摸爬滚打,使我们厂在制造一支独秀的产品同时也造就了一支专业化的优秀员工队伍。我们深信;只有高素质的员工,才能制造出一流的产品,而只有一流的产品和一流的服务,才能使顾客满意。
  在电子行业中,能否及时提供创新的高质量的产品是评价一家公司实力的重要依据,而你选择一个最合适的合作伙伴是节约您的宝贵时间、金钱以及内部资源的关键。而这些正是翼昀所能为你提供的特殊优势;能独立为顾客设计最合适的控制器、充电器、对顾客各个方面疑难能在三个工作日回复并解决。
  2005年6月初,我公司全面通过ISO9001-2000国际认证,多种产品已通过UL、CE认证,产品性能、质量更加稳定、可靠、更能满足新老顾客的要求,我们努力打造" 翼昀"品牌,竭诚为广大客户做坚实的后盾!共同发展,共创美好明天! ;D ;D ;D
jomac
LOL....i'll have the number 53 with the special fried rice and the extra cooling fan... ;D
aandu
Ogb, controller says 36V on the sticker. Is it variable voltage and what is the price?
ogb
#11
aandu
is also in 24volts see my website or google on (yk42-2)
(otherwise I am not according to the rules of this forum)
