Author Topic: Electric control system  (Read 2856 times)
LPODonovan
« on: 10, September, 2011 - 19:20:31 »
Needing some help with a C5 control system.  My C5 came with no wiring, no control box, no indicator panel.  What i have got is a motor and a battery!  I know the motor works as if I connect the battery it spins.
Questions;
1) Has anyone made up a simple safe control system?
2) Can I wire up a simple on/off switch between the battery and the motor?
3) What signals (from the indicator panel) are critical?
I am NOT going for a concourse C5 just something that is safe when driven.  Thanks for your guidance
« Last Edit: 10, September, 2011 - 19:50:22 by LPODonovan »
Re: Electric control system
« Reply #1 on: 10, September, 2011 - 19:28:32 »
You can run it with a relay and a switch, Radiomarty or Karl should be able to help with the connections etc, very basic but works fine, several people are using this setup.
LPODonovan
« Reply #2 on: 10, September, 2011 - 19:48:28 »
Thats amazing and thanks for the swift reply!  Ill contact the guys and buy those parts
« Reply #3 on: 10, September, 2011 - 21:06:34 »
The c5's mentioned running on just a relay are shown here;
http://c5alive.co.uk/forum/index.php?topic=1182.0
http://c5alive.co.uk/forum/index.php?topic=1208.0
...I cant remember where the diagram is but when I get a moment I'll make a few kits up - but it wont be before Brooklands due to other commitments
