Hydraulic Disc Brake
Started by dave in hull, 19, September, 2011 - 16:35:05
dave in hull
Hi all anyone no were you can get a Hydraulic Disc Brake Hub small enough for the front wheel can only find 100mm and the forks are 85mm cheers
coverman
Why hydraulics? extra weight and complication to stop a very light vehicle.
coverman
Make sure that the rear braking power exceeds the front otherwise a jacknife is likely.
vanpeebles
Imagine if it said on the news that a road was closed due to a jacknifed C5  :P
