How to lock a C5 effectively?
Started by Elias, 01, September, 2008 - 05:55:11
frankev
I found an easy way to lock my C5. There are two holes under the battery, for drainage I assume. On the other side there are also two holes.
Just take a piece of steal-cable and make a small circle through the two holes. close the circle with a cable clamp and presto, you can take a bicycle steal-cable lock through the ring under the c5 and connect it to the world somehow, lantern post, whatever. If you do this on the battery side, you can put a metal strap around the battery and also through the steal-cable ring. That way it also saves your battery from changing owner involuntarily.  8)
It works!
Frank
