Is my 3 month old battery starting to fail?
Started by kamilb1998, 03, January, 2012 - 10:53:37
Hi guys,
I went to a show yesterday and my battery only gave 4.5 miles of range, this was with the motor on  for pretty much all those 4.5 miles. Is it normal for the range to drop from 13 miles on a warm, sunny day to 4.5 miles on a cold, winter's day?
Quite a few people's batteries lately are suffering from loss of range due to cold weather. I would not of thought that much but different batteries suffer differently. I have Bosch S5 that don't seem to be suffering as much but I have not done any long runs lately.
Hope this helps
thedesigntailor
Hi Kam
I'm finding the same - range has dropped massively in the cold.
This is why launching the vehicle in the middle of winter wasn't one of Mr Sinclair's best ideas ! :) :)
Went to school on it today, and I got there and back (4.4 miles) with the lights on and the motor on for most of the journey and I returned home with two red lights remaining on the POD.
..battery range does drop considerably in the cold , but be careful not to over discharge the battery as they seldom recover from that.
Quote from: BooBoo on  04, January, 2012  - 20:51:28
I am running the original keyswitch & pod assembly so was sort of hoping that if I stop using the battery when the 'brain' cuts power to it after the 20 second beep, I should be OK. Someone correct me if this is not the case?
Just also check red cables POD to control box and also the connections to the key switch / battery housing as these get a bad connection and can result in incorrect LED indication on the POD. Also are all the POD pins solder joints ok, worth a check.
..the battery protection circuitry fitted to the c5 is useful but shouldn't really be trusted 100% , use it more as a guide.
It is a 26yr old system after all  :)
Managed to cover 7.9 miles today (outdoor temperature 4 degrees). So it appears to be getting a little better now I've come to use it a little more again.
thedesigntailor
Mine was a lot better yesterday - about 5 miles and only lost one light.
