Thanx Karl! Jonny5 is up and working again!!!
Started by Wizbat, 03, September, 2008 - 23:08:39
Wizbat
Hi to everyone I met on sunday.
Repairs to J5 are all finished and I,m going out for a test run tomorrow.
I got a bit carried away tonite and have stripped down just about every bit that moves and cleaned and lubricated the lot.
I now have a battery strap that is long enough to go round the monster battery, I used the old battery harness that I got with the car so it all looks how it should.
thanks again and cheers to martin for the wiring advice!!.
c5martin
Excellent News! :)
If you have any other problems just give us a call!
I will try to be with it next time.
I was a bit sleepy and brain dead when you called. 8)
Glad to hear you're back in the saddle again mate.
You've got a really nice C5 there, it was worth the effort sorting those little snags  ;)
Wizbat
I took it out for a run after I got it all back together and it really runs nice and quiet.
Did martin mention the problem I had with the axle bearing where it fitted into the new motor mount? I had to glue the bearing in with araldite, I,ll see how it holds up over the next couple of weeks.
Just got to figure out a nice sympathetically fitted stereo, Got to have sounds when on the move!!!
If the araldite fails,let me know I'm sure we can sort it   ;)
Have your mates stopped badgering you to borrow it yet  ;D
Wizbat
Quote from: Wizbat on  05, September, 2008  - 19:09:27
I,m thinking of charging them a pint a go!
you might end up with enough "surplus beer" to set up your own pub  :D
