Twin Battery models
Started by kamilb1998, 25, March, 2012 - 22:00:22
Quote from: PLOD11 on  02, April, 2012  - 18:19:38
Just had a look in the shed and have found a working one  (I think) never used one so not sure how it works, but it has all the cables attached and it takes any key to turn it. Its prings back when you press the red button.
You are welcome to it, (i wont ever use it) e mail me your address if you want it.
PM'd!
Quote from: fezza_rs on  02, April, 2012  - 17:42:43
If you post it to me I'll happily fix it for you for the cost of a jiffy bag and a stamp!
Thanks for the offer, but I have emailed PLOD11 so there isn't much point fixing this one.
#17
In the post tomorrow, worth keeping the old one might be of use to someone .....
That's what makes this website a step above the rest !! :) :) :)
Quote from: radiomarty on  02, April, 2012  - 19:33:22
...makes all the effort worthwhile  8)
Certainly does! ;D
Thank you very much PLOD, the keyswitch arrived in the post today - I will send you money to cover the postage and a pint for you mate ;)
Fitting it was quite simple, the only thing that 'annoyed' me were the two different nut sizes inside the control box - one was an 8mm & the other was a 9/32. I undid the 8mm and then proceeded to undo the second one and after about 20 mins. of failing to turn the nut with an 8mm socket I tried a different size.  ::)
Just need to fabricate the bracket to hold the second keyswitch when it's not in use.
Pictures;
Finished making the bracket. I will get some better pictures up soon.
Nice one, looking good Kam.
looking great well done ..Chas
No problem ...   8)
Its Looking good  8)
My conversion appears to be working well & the range may have increased slightly too - 11 miles covered & I didn't lose any lights on the POD's battery conditon display.
Quote from: kamilb1998 on  06, April, 2012  - 17:04:12
That's a good range, it also helps you're quite lighter than lardy middle aged guys like myself....after a few more years though, once the booze and kebabs have taken their toll on your body :-X , you'll find that the range on your c5 seems to suffer as well  :o ;D ;)
BooBoo you forgat the Chinese & Indian takeaways as well......................................
;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
There is a reason why Sinclair introduced the second battery option as it gives a much better performance as Kamilb is seeing and helps with the middle age transportation needs  ;) The only downside I can see is you cannot carry a spare just incase battery but you always have them there pedals ! :D :D
