front light
Started by plumber, 13, April, 2012 - 04:45:00
plumber
hi there......have a go with these bad boys http://www.ebay.co.uk/itm/290654203389?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
very good.......and you can see where you are going lol
the plumber
fezza_rs
Hi there I also buy and use the above LED bulbs ..
plumber
yes i have... you can see where you are going..lol....they are very good
many thanks
the plumber
Won't LEDs look a little out of place on something as old as a Sinclair? ;)
plumber
well every one to there own choice......lest i will be able to see where iam going in the dark :P not like a candle in the wind ;D
the plumber
The one on the left is a standard bulb, the other one is LED. Not the same one that Plumber is using but very very bright and white light, his one also has a strobe mode, by swtiching on and off once ...
That actually looks quite good. I was expecting it to give out a strong blue colour.
Any chance that the stronger bulbs would end up effecting the wiring if the bulbs get too hot ?
Led bulbs use less current than standard - so even though they are brighter they don't get as hot  ;)
I think the led bulbs draw so much less power they don't ever get anywhere near as hot as a normal filament bulb, so the headlight unit should in theory be even safer....unless it all shorts out and gets melted like it did once on "moneypit"  :o
