Plastic inserts with metal tooth Pulley
Started by C5 ENTHUSIAST + RESTORER, 24, May, 2012 - 18:27:34
Hi all .Just had some new inserts made out of the original Plastic insert and a metal toothed pulley
Two of the plastic inserts where posted to me from members and I thank them .
If there are interested in buying one I will give them a discount  .
The inserts will be posted for sale on The Chas section later on...Take a look at the photo
Now that is a good use for some worn parts...some superb recycling  8)
Thanks Karl .
The inserts have had the teeth cut off then drilled out . The metal pulleys have been cut down and made to fit a 18 mm belt and pushed in the insert , Then a hole is drilled and a pin pushed through ..making them very strong ....(You can see one of the pins in the first insert )
No more worn teeth .....
The next thing I will be doing is to have the 3 pins made up (the one's that the small cogs fit on) Also going to have at having the 3 small cogs made ....I have already had the the large cog made up out off aluminum.. Photo's to follow
Hi Chas - how about offering a repair service for peoples worn cogs ?
Thanks Yes you right I could offer a repair service but before that I need to put them on a C5 and just check them out ....I sure they will be up to it but I will test them out all the same ..And if it goes ok I will have more inserts made up for sale
Bye Chas ........
That may help the one that I melted trying out the current tranducer.
As soon as they have been tested I will be offering an exchange service as long as it is only the teeth that are worn down ..
Let me know if anyone is interested in them ...Bye Chas
Me - depends on cost though....................... :o :o :o :o :o :o :o
Hi there Lance the cost would be £38.00 + postage ...+ the old insert ....
bye Chas
