Large drive cog
Started by C5 ENTHUSIAST + RESTORER, 01, June, 2012 - 17:38:53
Hi all just had the a large cog that goes on the axle made from aluminium as you will see it looks and runs OK
Check out this link ...http://www.youtube.com/watch?v=XwasKwK3w2o
Good job there Chas - looks much more durable  :)
A fantastic replacment for the plastic cog when cracked, top job again Chas.
Nice one chas, looks great, top job................
That will help to keep c5's motoring in the future  :)
SwedenBob
will it make the C5 faster?
cost?
#7
Hi all thanks for the comments ...Regarding will it go faster ....That will depend on the size of the small drive pulley at the moment the Large pulley has 72 teeth (the original has 68)  and the small one has 21 and the only way I could make it work is to fit a  410 belt and  turn the motor upside down to give more slack...(standard belt size is 400)  the speed is about 10 % faster . But I am waiting for a 18 toothed pulley and hope to have it made up soon and that will give me the same speed as the C5 should be ....
..I will keep you updated ...If you use the original 68 tooth pulley and a bigger drive pulley say a 25 tooth pulley it should increase the speed by about 10% ???.. But you would loose some torque ..
