Battery usage
Started by mhurt, 11, August, 2012 - 17:35:41
mhurt
Hi all,
Now that my C5 seems to be running well, I took it for a fantastic and leisurely ride along the canal, doing about 8 miles in total. It's all downhill to the canal, so the battery wasn't used, and I pedalled most of the time along the canal except for a few bursts of speed (pedal and power) and the tow path is pretty level. I had all battery bars lit when I came off the canal.
I used power mainly for the last stretch coming uphill back home, GPS has it down as 0.3 miles and some of that I was pushing, but when I got home I was down to 4 bars battery.
The battery is a brand new 75Ah SLA one.
Does this sound about right, would the pod correctly display the power left on a high capacity battery, or have I got an issue somewhere?
Cheers and sorry for being such a worrying newbie!
Hi - If you lost only one green LED I wouldn't worry as I have had this with brand new battery's after a very short while but then it stay on the second green for ages - take it for a run using a combination of battery and pedaling to keep the motor load in the green and see how you get on - let us know  :) :) :) :)
mhurt
I will do.
Not sure I counted all the bars right, but it was the left amber the amber lit and reds - no greens showing. I guess Im panicing a bit as I just don't want to end up pushing all the way uphill back home - which I wouldn't be able to do.
From experience, when would you start thinking "I'd better just pedal so there's a bit of juice to help me up that last hill"?
mhurt
OK, it seems to be the pod reporting the level wrong.
After a bit of heavy use, the batter level drops into the red, but if I pop the negative lead off and on again - full battery. The seller did say that it has non- standard electrics from the control box, so maybe it's that? The only problem is, I don't actually know what charge level I have :p
It also looks like I need to fit a cooling fan, as the pod started beeping at me half a mile from home today. It was quite warm, but I got caught in torrential downpour 3 miles from home with no coat, so I was trying to get back as fast as possible. Ended up taking shelter under a tree for 15 mins :) but that's a project for another day!
Hi - When you disconnect and reconnect your battery it is normal for the pod to reset to full condition - it does sound rather a quick drop on the battery indicator which may be a duff pod  :(
mhurt
mhurt
Having emailed radiomarty, it definitely looks like the ULA chip.
I'm looking at Phil's instructions for building the ULA replacement board and if I can get my head around it, I might be able to make a few (it's about 20 years since I did anything like that, so need to brush up on a few things first), or maybe have a look at an Arduino/Raspberry Pi based alternative.
In the meantime, I'll get a battery level monitor and something to monitor the motor temperature.
