2nd Battery Upgrade
Started by dansretropod, 05, September, 2012 - 14:55:48
dansretropod
Hello everyone,
I'm new to the site and have recently got my first C5 which is great fun driving around in:)
Just 1 question, what are the advantages of using a 2nd battery, I know it can extend the range, but would it also help when going up hills as at the moment my C5 struggles with hills which I believe is normal.
Thanks!
Dan
It would extend your range but unfortunately won't help with climbing hills. For that you need a 24V conversion which wouldn't be legal anyway.
mhurt
Could possibly go for the dual motor approach that Chas made http://c5alive.co.uk/forum/index.php/topic,2402.0.html
Not sure that would be entirely legal though, but it's something I'd definitely like to try at some point in the future, as I have to get out and push on some local hills.
Hi there talking of my 2 motor C5 I will be putting it up for sale soon
mhurt
Damn - the missus would kill me if I bought another (not to mention the bank manager!).
Will keep an eye out though, as I know someone that's after one since they tried mine out :)
coverman
Having two motors means 500W, twice the legal limit.
dansretropod
Thanks for all the advice guys, I'll stick with the standard 1 motor + 1 battery setup. There's only the occasional steep hill/speed bumps where I live so it's no big deal pushing it.
I imagine trying to pedal a C5 with the extra weight of 2 batteries and 2 motors is hard work anyway.
Thanks!
coverman
I live in a hilly area and just keep pedalling whilst the motor is running
mhurt
Quote from: coverman on  07, September, 2012  - 12:09:17
So do I, but the flipping things are too long or too steep (or both!) for that to work :)
I usually have a 100m stretch where I have to push, or extras if I have to stop going uphill for some reason. I'm considering a couple of options that would get me up these, but at a slower speed (around 4mph) and not using the C5 motor
dansretropod
Yep, some hill's you can't get up even by peddling and using the motor;)  I may look into getting a lighter battery such as the LiFePO4 batteries which are much lighter than a lead acid battery, though much more expensive:(
QuoteI'm considering a couple of options that would get me up these, but at a slower speed (around 4mph) and not using the C5 motor
I like the idea of getting the C5 to go slower up steep hills you'll have to keep us posted.
Quote from: dansretropod on  07, September, 2012  - 17:31:05
I've never had a problem getting up a hill, even if really quite steep, and I very rarely pedal. I nearly always carry two batteries at 32kg and am 9 stone myself.
mhurt
Quote from: kamilb1998 on  07, September, 2012  - 19:25:55
I'm 6 stone heavier than you, just about 41 and, until a couple of months ago hadn't ridden in 25 years :D
I'm sure that after a while, I'll get more strength and stamina, but even then there will be periods where I have problems due to a health condition, so I could still do with a solution eventually :)
Robosoft
Quote from: coverman on  06, September, 2012  - 10:28:21
Is that true ???
the top speed would be the same. it would just have more torque (given an illusion of more speed up hill).
if you had 2x c5 strapped to each other the top speed would be the same.  each motor can't go any faster than 250w unless more power was introduced.
So I say it legal.
If still not sure just peel off the 250w stickers and replace them with 125w.
coverman
The legal power limit is 250W.
Separately, yes two motors would obviously give twice the torque and twice the power, and therefore collectively may pull a few more revs allowing marginally higher top speed on standard gearing, also illegal.. Again ,obviously, if geared up, a higher top speed yet would be facilitated.
The increased power of two motors wouldn't give an apparent increase in speed up an incline, it would give an actual increase in the speed.
Quote from: Robosoft on  08, September, 2012  - 22:49:49
So I say it legal.
A guide to some of the rules, that are always changing,  are found here;
http://c5alive.co.uk/forum/index.php/topic,1074.0.html
Fortunately for us the recent pedelec changes are not retrospective so we do not have to fit the Dutch style pedal sensors etc.
I would suggest that fitting two motors would push you outside the guidelines in both power and weight.
