Author Topic: indicator  (Read 3197 times)
indicator
« on: 30, October, 2012 - 21:03:16 »
Dose anyone know how you get into the rear indicator bulb as we cant get into it to change the bulb.
Re: indicator
« Reply #1 on: 30, October, 2012 - 21:51:22 »
Hi there not sure how far you have got but first of all you need to take out the two screws in the back light .Then ease the back light up a little then it should come away ..You will then see the bulb holder (black rubber outer case) You will find it's very tight and hard to get off .
Be carfull ..if and when you get it off replace the bulb but before you put it back together put a little grease /oil on the rubber then it will be easer to remove the next time .. Chas
Re: indicator
« Reply #2 on: 30, October, 2012 - 22:06:42 »
Hi there I read the question wrong and got the answer wrong sorry .
regarding the indicator bulb you have to take the indicator off to get at the bulbs ..
If you look at the back of the indicator you will see two spring clips take them off and ease the indicator off but as before be carfull you may break  the lugs off..
The bulbs are called FESTOON ...
« Last Edit: 30, October, 2012 - 22:11:47 by C5 ENTHUSIAST + RESTORER »
Re: indicator
« Reply #3 on: 31, October, 2012 - 14:31:47 »
I know i talk alot but is the black rubber inside the indicator meant to be glued down as ours is.  :( :( :-\ :-\
Re: indicator
« Reply #4 on: 31, October, 2012 - 14:54:29 »
Hi there no they are not sticky but some do glue them down ....when the lugs break off ....(Thas if you are talking about the black foam rubber sealer ...)
