Removing Gearbox Problems
Started by KarlG, 12, November, 2012 - 20:19:38
KarlG
I've followed the instructions shown in http://c5alive.co.uk/forum/index.php/topic,1217.msg9622.html#msg9622 with no success, the gearbox will just not move. Trying to twist the case to free it up is useless as it's keyed
I'm a bit worried in-case I shatter the case, it's a brown one (no brown fingers). After reading about the brown finger problem I'm wondering if the brown casing are from the same material.
Can anyone suggest how I can remove this  gearbox?
As long as all the 'tabs' are open, the gearbox casing should be free. Do try and give it a good tug - mine rarely comes off lightly and does often need some gentle persuasion.
ETA: My old casing was white and actually was the one which seemed to have been made from a softer material compared to my new brown one.
KarlG
#2
Hi Kamilb,
thanks for your post, BUT.
I've checked all the tabs and all are clear.
I have, as you termed it, given it a good tug, a few dammed good tugs, but it wouldn't budge. I now have some nasty teeth marks around the rim and I'm now at the point that I may tear or rip off a section of the rim.
Well in that case you'll have to wait for someone a little more experienced to come along, mine's always come off with some gentle persuasion.
The only other thing I can think of is are you pulling it straight towards and not at an angle?
KarlG
#4
Ah! now we are getting some where.
What angle?
EDIT: From Karl's description:
QuoteYou must be careful here and pull in a straight line - otherwise you risk damaging the gearbox housing;
[/color]
I suspect you may have misunderstood my last post, it must be pulled in a straight line and not at an angle. I have quoted below what Karl's said about it on the thread in your link.
Quote from: BooBooYou must be careful here and pull in a straight line - otherwise you risk damaging the gearbox housing;
KarlG
#6
I think I'm suffering from Déjà vu.  ??? The quote I quoted previously is from the other Karl not this one.  8)
No I was pulling in a straight line, pulling from one side then the other.
Quote from: KarlG on  12, November, 2012  - 22:35:29
That's confused me now  :-\
But if you were pulling in a straight line then you were doing it correctly and it should have come off. Will have to wait for one of the more experienced members to tell you why yours may be stuck.
Hi there one of the way's I use to get the gearbox off is to open the fingers gently (If you had the brittal one's then they would have broke of already regarding the colour it is not brown it's a kind of purple ish )..as the fingers are open get a screw driver and prise the gearbox using the two bolts as a fulcrum one side at a time but be carfull ...If that does not work .Just give me a ring and I will run you through it ..bye Chas
KarlG
Hi Chas,
there is no gap between the gearbox and the 'finger assembly' to insert a screwdriver, the gearbox has not moved a fraction of a mm.
I did read somewhere about greasing the gearbox from the rear, is it possible to remove the armature from the 'finger assembly'?
Yes you are right but you have to make a gap by easing the gearbox up with the screw drivers ....Beaing carfull not to damage it ...I will put some photos on later ...Bye Chas
KarlG
OK olé!, thanks Chas.
Will hold off till you post.
#12
Hi here is one I made Earlier  (G/box puller ) Take a look at the last photo how I sometimes take the G/box off ..But you must prize the fingers open first
KarlG
Lovely piece of workmanship there Chas, and not beyond my capability to reproduce. But, for only three motors and long service intervals, I think it would be over doing it somewhat on my part.
I'll just have to make up a couple of grip blocks and try pulling with the vice.
I always spray WD40 into the join between the gearbox casing and the fingers
Several strong tugs, rather than a single long pull, always work better as well (cant believe how pervy that sounds  :o ;D)
