Removing Gearbox Problems
Started by KarlG, 12, November, 2012 - 20:19:38
KarlG
Well I managed to remove the bl...y thing at last,  ::)  it's the most nerve wracking job I've had in many years. In the end I had to strip the unit down and then use the vice together with a couple of grip blocks. I still had to use a hammer and wooden block, with each blow 'ping' and a nail would fly out. This happened so often it drove me up the wall across the ceiling and down the other side,  :o :o  so in the end I removed the nails and made some plastic wedges, and this worked, but it still took a lot of hammering and rotating the unit before the gearbox came out.
The cause of the problem was at some time or other a load of very sticky gunge had been poured over part of the motor and most of the gearbox, I had a hard job to clean this off when I removed the motor and didn't think about it anymore. This gunge had penetrated into the gap between the gearbox and the finger assembly, I assume with time it had started to harden and make a very efficient seal.  :-\
Anyway the gearbox is now clean, thank goodness, and awaiting greasing and reassembly.
KarlG
Hi Chas,
are there replacements for the large gearbox bearing?
Cheers.  KarlG.
Hi there Karl yes they are ....No problem ...Bye Chas
KarlG
Hi Chas,
who much will it hurt me?
KarlG
Luke S
Several strong tugs, rather than a single long pull, always work better as well (cant believe how pervy that sounds  :o ;D)
[/quote]
LOL ::) ::) ::)
KarlG
Quote(cant believe how pervy that sounds  :o ;D )
And that at your age.  :o :o :o
