pod lights
Started by Luke S, 26, December, 2012 - 13:05:19
Luke S
what do the pod lights mean on the left and the right hand side  ??? ??? ???
#1
Hi there Luke take a look at the photo's ....Sorry about the contrast of the photo's if you cannot read them let me know ..
Luke S
The lights on the right hand side means the battery condition, those lights go down then the C5 starts beeping at me, the battery is charged up and I got the C5Alive battery clamps about 2 weeks ago, we cleaned the connections when I had a different battery and the key switch it worked fine fir about 2 weeks then it started playing up again so that was when we bought the battery clamps, the C5 worked great for about 2 weeks again now its started to do what happened when I had the key switch, do you think the connections on the battery could be dirty  :-\ :-\
The C5 seems to be very complicated for what it is
Thanks, Luke
Hi Luke - It sounds as if your ULA chip has a defect as this is a classic fault pattern - the only odd thing is that it works for a couple of weeks then starts doing it again - please check your thin brown wire is correctly connected in the control box and that the spade it pushes onto is has a good soldered joint - also make sure the red connector block on the back of the pod is good (ie when you wiggle it does the pod go off) Check the pins on the pod are clean and that the soldered joints are good - If all else fails you could send it to myself and I can test it for you for free if you cover the postage both ways - Marty :)
Quote from: Luke Salsbury on  26, December, 2012  - 20:28:58
Not really, it's just getting quite old now and with most of the components starting to exceed their design life the number of problems will start to increase .
As a comparison, consider this - how many cars from the mid 1980's are still even out there running about, let alone doing so reliably ?
Luke S
Quote from: radiomarty on  27, December, 2012  - 07:33:08
What is the ULA chip and where is it on the C5
Luke S
don't worry my dad knows
Luke S
What can you do if this has gone
Luke S
Quote from: BooBoo on  27, December, 2012  - 08:44:40
My dad has 2 1972 GT6's they run fine, they have probably been looked after well
Quote from: Luke Salsbury on  27, December, 2012  - 20:02:14
Sadly at the moment there is no replacement - however Karl G is looking into it think - I need to contact him when I get a few spare minutes !
Quote from: Luke Salsbury on  27, December, 2012  - 20:29:04
...and I expect the GT6's cost a lot more than a c5 and have had considerably more spent on them in restoration, maintenance and general running costs - just like my MGF . Horses for courses  ;)
Luke S
I have sorted out the problem by cleaning the battery terminals and the connections on the back of the pod, I'll go out on it sume time and see if it still works.  :) :) :) :)
Luke S
I took it out just now and the lights on the pod went down then started beeping again >:( >:( >:( >:(
Luke S
#13
I did not go far and I put my hand on the motor and it was warm. Is it meant to get warm if you have done about 1/4 of a mile
Luke S
I have cleaned the terminals. Then once I have done about 100 meters the 2 green lights go out. Then once I have done about 1/4 of a mile it starts beeping at me, what dose the beeping mean/ telling you???????????  :-\ :-\ :-\ :-\
