pod lights
Started by Luke S, 26, December, 2012 - 13:05:19
Hi Luke, the red cable loom has 9 wires connected to a 10 way connector.
You will not get a reply from Phil as he has left the C5 forum unfortunately but he left the POD replacement a freeware.
Luke S
Quote from: Lancealot on  01, January, 2013  - 20:01:22
Thanks Lance  ;) ;)
Has any one made one of these ULA replacement modules before, if so approximately how long would it that my dad to do
Luke S
I have bought a pod off eBay hopefully it will work :D :D :D :) ;)
Luke S
Quote from: Luke Salsbury on  01, January, 2013  - 20:56:00
The pod I bought is different to the picture on eBay according to the seller so it probably wont work :( :( >:( >:(
KarlG
You were assured yesterday that it would work, why not wait and see.
Luke S
Quote from: KarlG on  02, January, 2013  - 18:52:22
It works!!! :) :) :)
But now the motor dose not work, dose any one know how to get round this problem
Luke S
Also are the lights on the left hand side meant to flash when the c5 is not moving
Dave.76
Hi Luke
Sorry to hear you are having problems. As far as I know, the left hand set of LEDs shouldn't flash when stationary. They certainly don't on my C5. As far as I am aware only the outer set of orange LEDs  on the left hand bank should stay on (not flashing) when the motor is not in use.
Luke S
Year the 2 orange ones on the left hand side don't flash
Luke S
May be it's flashing because the motor wont work. The motor works fine with the other pod but not with this one :-\ :-\
dansretropod
QuoteThe motor works fine with the other pod but not with this one
Looks like your new POD is just as broken as your old one.  Have you considered removing the POD and control box and just running your C5 from a relay?  It'll save you all the hassle/cost of dealing with faulty ULA chips.
Luke S
I'll just see if I can get my dad to look at it tonight
Hi Luke- sounds like possibly another duff pod - the offer is still there if you want to stick them in the post to me I will see whats wrong with them for you - just cover the postage (£4 ish) - Marty
Luke S
I'll talk to my dad when he gets home.
Can you swap ULA chips over between 2 pods :-\ :-\
dansretropod
Yeah you can swap them over.  Just be careful to handle them correctly and protect them from static.
