Dual-battery C5?
Started by Howard81, 15, January, 2013 - 16:01:52
Howard81
Taking a closer look in the right hand footwell in my C5 last night I noticed that it has holes for both ends of the battery strap, rear battery "foot" and a bracket to hold an additional keyswitch.  There's also a sticker on the central tunnel advising to turn on both batteries if two are connected.
Does this mean that it was originally fitted with a dual-battery setup?  Or where they like this from the factory, then a second keyswitch purchased and fitted if required?
It doesn't currently have dual-battery electrics, would it simply be a matter of getting another keyswitch assembly and "doubling up" on the connections so the two batteries work in parallel? :D
That does look like it was a dual-battery model. The keyswitches do simply double up on the connections - a very straightforward job to do. I did it on mine several months ago.
marra
If you decide not to go back to 2xbattery then you could sell the bracket in the well ( holds the ignition block ) , ive seen these sell for £10 +, like many c5 parts folk will pay prices.
Howard81
Excellent, that's a nice bonus to find out.  In all honesty I'd like to put it back to dual battery if I can find the parts! ;D
Hi there Howard just posted you an answer on your  other post .bye Chas
