freewheel ?
Started by thedesigntailor, 11, April, 2013 - 12:48:06
thedesigntailor
Hi chaps
I really want a 24v upgrade, but know there are reliability problems.
As someone who doesn't know the correct end of a screwdriver, I understand the 'gearbox' has issues taking the power.
I was thinking about if it was possible to use a freewheel - like on a bike drivetrain. So the power will
I'm sure there is a good reason this isn't possible, but I thought I'd ask.
coverman
A freewheel is designed to prevent over-revving on the overrun. It would not help a fragile gearbox.  A cushdrive would help, but its probably quicker to build a metal gearbox than design develope and build one of them and it would only mask the gearbox weakness for a while.
thedesigntailor
Thanks - would a brushless motor need a gearbox?
coverman
A reduction drive of some kind would probably be necessary as a torque multiplier and rev reducer.The box stock C5 motor revs to 3300 rpm (from memory), what does your intended replacement motor do? Does it develop maximum torque at lock?
