Author Topic: Hi from Malcolm in Sydney  (Read 3332 times)
Offline malfunction
« on: 14, April, 2013 - 03:29:52 »
Hi , My name is Malcolm and I am a C5aholic.
The last (and first time since I was a kid) time I rode a C5 was yesterday.
I have been looking of a C5 for a while, and met a guy with some to restore. One of which will be mine.
My progress restoring the C5s is documented  here. http://malfunction.faed.name/search/label/C5
I am almost done identifying what parts I will need and will need to go shopping.  ;)
I look forward to 'meeting' you here..
Malcolm.
Re: Hi from Malcolm in Sydney
« Reply #1 on: 14, April, 2013 - 08:16:00 »
Welcome to the forum  ;) ;) ;) ;)
« Reply #2 on: 14, April, 2013 - 09:20:37 »
Welcome Malcolm any help you want just ask ....bye Chas
Offline thedesigntailor
  • designer and C5 newbie
    • GLOW creative
« Reply #3 on: 14, April, 2013 - 13:35:51 »
Hi Malcolm
 I see you are from Australia - welcome!  ;D
Offline Dave.76
« Reply #4 on: 14, April, 2013 - 13:47:50 »
Hello Malcolm
Welcome to the forum and good luck with your C5's.
Dave
« Reply #5 on: 15, April, 2013 - 20:45:44 »
Hello and welcome to the C5 Alive forum, Please post us some sun shine this way  :)
« Reply #6 on: 18, April, 2013 - 10:39:30 »
Welcome to the forum - enjoy  :)
« Reply #7 on: 19, April, 2013 - 20:16:43 »
glad to have you aboard mate  8)
Offline malfunction
« Reply #8 on: 30, April, 2013 - 13:08:06 »
Not sure of the best forum for tech notes, but here is some data on the motor and gearbox components.
C5 drive components
Planetary gearbox output drive pulley:
- Diameter ~31mm
- 21 tooth
Axle Drive pulley:
- Diameter ~107mm
- 68 tooth
- One Way Bearing INA HFL 2026
Drive Belt:
- Length = 400mm
- Width = 18mm
- Teeth = 80 tooth
- 5mm Pitch
- Megadyne Isoran 400 RPP5
- Local .au equivalent - 400-T5 80 400.0 from http://www.naismith.com.au/catalogues/pulleys/metric.pdf
Final ratio = 21/68 = .308 or a 3.23 reduction.
Replacement Aluminium Pulleys from Naismith in Sydney:
- Large = 60 60-T5-16
- Small = 18  18-T5-16F for similar final drive ratio.
Could use 25mm wide pulleys to allow for machining.
Motor Bearing - Both Ends: GMN 6201 - data http://www.gmnbt.com/deep-groove-bearings-selection-guide.htm
Planetary support bearing x2 (on drive end of motor shaft) GMN 607
Large output shaft bearing 61808
3 x Gearbox planet carrier shafts ~ 8mm
