Limiting the voltage of the original charger
Started by gertk, 11, May, 2013 - 17:36:00
gertk
Today I tried to reverse enigineer the original C5 charger. The new battery I got must not be charged with a voltage over 14.4 Volts but the original charger goes up to 15.7 before throttling down and that might destroy the battery.
The controller is a potted circuit board with mostly unrecognizable parts. There is a single 100k resistor connected to two pins but changing the value of it does not change the maximum voltage.
Has anyone tried to modify the charger ? Are there any circuit diagrams for the charger ?
If not I could try to make a new 'controller' which re-uses the power parts (the SCR's and such) and will generate the right charging curve for the new battery.
Hi there .There are no circuit diagrams for the charger . And I have never tried to modify the it ....
gertk
I decided to keep the original charger in its original form and have bought a HQ 7-stage intelligent charger which will be mounted in the boot with an extension cable ready to be plugged in anywhere...
