Author Topic: Indicator option  (Read 12118 times)
Offline rekooh99
Re: Indicator option
« Reply #15 on: 22, June, 2013 - 20:38:30 »
Gert, looks absolutely brilliant ! great work!
« Reply #16 on: 22, June, 2013 - 21:23:46 »
Well done they look great .....I may have a go myself ..But at the moment I am in the middle of restoring another C5 (it's the third one this month ...)
Chas
« Reply #17 on: 23, June, 2013 - 08:32:36 »
Thats really good - may have to upgrade Goldfinger ;)
« Reply #18 on: 23, June, 2013 - 10:09:37 »
..that is a really good upgrade, love it  8)
Offline Pep
« Reply #19 on: 23, June, 2013 - 22:17:11 »
Excellent mod very impressed !
Offline gertk
  • Battery level: 6
  • When in doubt: C5
« Reply #20 on: 25, June, 2013 - 22:06:22 »
Could not resist to build a 2 pin flasher so I searched the web and tried two designs: a transistor based flasher and a power FET based one. The transistor based one was very frequency dependent on the load, the FET based version worked much better and after some experimentation I came up with the following circuit:
Offline gertk
  • Battery level: 6
  • When in doubt: C5
« Reply #21 on: 25, June, 2013 - 22:15:51 »
Some more pics of the 'circuit board'
Power side:
Small signal side  ;D
The board can be put in series with the positive cable to the indicator switch (central pin) and functions just as the thermo-electric two pin flasher. I tested the circuit with the LED indicators and also with a 20 Watt halogen lamp and it works equally well.
Because of the low on-resistance of the FET it needs no cooling. The duty cycle can be varied with the capacitors and the 180k resistor (I had already put in a 220k and added a 470k in parallel and the flashing duty cycle is quite good but a 180k would probably make it just right..)
Offline gertk
  • Battery level: 6
  • When in doubt: C5
« Reply #22 on: 22, July, 2013 - 19:08:47 »
The front 'pods' finally came in, mounted them together with the mirrors this Sunday. Meanwhile the battery was charging from an abundance of solar energy...
Although the brightness of the pods is good the viewing angle isn't... But in the dark they are quite visible..  ;D
Next step: pedelec sensor...
Maybe something like this:
Offline c5mick
« Reply #23 on: 22, July, 2013 - 22:12:14 »
Hi
Does anyone have the link for these on EBay
Regards
Mick
Offline gertk
  • Battery level: 6
  • When in doubt: C5
« Reply #24 on: 23, July, 2013 - 06:37:46 »
Try searching for 'led pod' on eBay (for the pods that is)
The pedelec sensor (or dutch: 'trapsensor') is available from all kinds of webshops and searching on ebay on 'pedelec sensor' gives also a lot of results.
Mind though: you need to add electronics to enable/inhibit the C5 motor relay as the sensor is just that: a sensor to detect that you are pedaling.
Offline Jonatan
  • Rollin' Rollin' Rollin' Keep the C5s Rolling' C5!
« Reply #25 on: 16, August, 2013 - 20:42:23 »
hi there,
actually you dont need expensive sensors around your wheels, I just got cheap reed switches and mounted them with hot glue. Then I took neodenium magnets to trigger the switches and it works great! You can keep it simple! Gonna post some pictures tomorrow!
Yours,
Jonatan
Offline gertk
  • Battery level: 6
  • When in doubt: C5
« Reply #26 on: 17, August, 2013 - 18:29:45 »
hi there,
Actually the sensor and magnet disc I bought were just EUR. 7,50
Offline Jonatan
« Reply #27 on: 19, August, 2013 - 17:43:34 »
Hi there,
oh wow! Thats very impressivee! It looks like 30! :-P
Yours,
Jonatan
Offline gertk
  • Battery level: 6
  • When in doubt: C5
« Reply #28 on: 22, August, 2013 - 06:45:36 »
Hi there,
Yours,
Jonatan
 :D
I got this one:
http://www.e-fietsspecialist.nl/shop/trapsensor/
Offline Jonatan
« Reply #29 on: 22, August, 2013 - 20:28:36 »
Hi there,
looks very nice indeed! :-) I just took normal reed switches and glued magnets on the big metal wheel that spins with the right wheel - Worked perfectly fine! :-) Yours looks more professional but both do the job! :-)
Yours,
Jonatan
