Lights!
Started by dantheref, 25, September, 2013 - 20:33:26
dantheref
My lights dont work, Can anyone guide me to which wires are for the lighting and any other possible faults?
The main issue with lighting is loose connection of the fuses in the control box - give them a wiggle and see if the lights come on - chec the connections at the back of the switch also - Marty
dansretropod
Yep, the fuses are always a good place to start.  If you're using the original bulbs I'd switch to using the low energy LED bulbs you can get off ebay for £2.50.
rekooh99
You can also get the led bulbs from the c5owners forum for the same sort of price.
dantheref
Thanks for all your advice all working now, with LED bulbs on the way!
