Author Topic: Drive belt  (Read 2386 times)
Offline Carl Gordon
Drive belt
« on: 06, April, 2014 - 16:39:27 »
Hi all, can anyone tell me where I can get a drive belt from?, mines worn and it keeps slipping,
Offline dansretropod
    • www.c5owners.com
Re: Drive belt
« Reply #1 on: 06, April, 2014 - 17:14:14 »
Try this one on ebay mate for £6.73, I use these in my c5s no problems:
http://www.ebay.co.uk/itm/321061905185
« Last Edit: 06, April, 2014 - 17:15:48 by dansretropod »
Offline Carl Gordon
Re: Drive belt
« Reply #2 on: 06, April, 2014 - 17:43:57 »
That's great, thanks
Offline patbrooks
Re: Drive belt
« Reply #3 on: 07, April, 2014 - 13:45:23 »
We sell 15mm and 18mm drive belts via the C5Alive shop, these are perfect replacement belts, which are the right size, long lasting and easy to fit.
OEM spec is 15mm but we also supply a wider 18mm version which can help reduce belt slip if the drive cog is worn ,identified as a loud "buzzing" noise when engaging the electric motor.
http://c5alive.co.uk/index.php?com=shop&display=product&id=30
Pat
