Author Topic: Hi from sunny marlow  (Read 1496 times)
Offline g4vll
« on: 09, June, 2014 - 15:24:58 »
Hello name chris  with  worn out knees and every other joint  worn out ,I am a 18year old stuck in a 65 year old body ' And on top of that i suffer from parkinsons  , Just picked up this c5 on ebay , number V1000411007777  that makes it an early one i believe ,It was a non runner but air in the cracked tyres  a battery wiring kit and a battery it runs , no leds show in the pod ,but a quick test and belt slip what a noise ,So a small piece of alloy shaped to fit under the gearbox and on the rear axle bearing held in with 1 pop rivet does the trick no more slips.
