Author Topic: C5 Motor dead?  (Read 16056 times)
Offline dansretropod
    • www.c5owners.com
Re: C5 Motor dead?
« Reply #30 on: 29, November, 2014 - 17:12:21 »
Chas is a star. If I could give you a medal on this site I would lol ;D
Re: C5 Motor dead?
« Reply #31 on: 29, November, 2014 - 17:15:54 »
Thanks hope all goes well
Re: C5 Motor dead?
« Reply #32 on: 29, November, 2014 - 20:40:47 »
the posting will be £25.00
Wow! :o It costs me almost this much to have a mag sent from the states. :( :(
Offline USA-C5-Owner
Re: C5 Motor dead?
« Reply #33 on: 29, November, 2014 - 21:00:28 »
Many Thanks again Chas, for all the help and the needed part.  Is a private message different than an email in this forum as I have not received any further emails from you?
And as mentioned before - I will make sure to list all my extra parts after the project is complete in case you or anyone else needs one of them.  Your member list here is a great group of guys, glad to be a part of it!
Re: C5 Motor dead?
« Reply #34 on: 29, November, 2014 - 21:25:59 »
Hi Adam sorry about the PM /email the reason is that the I dropped the parcel at the pickup point but it will not be picked up until Monday
 I will then have the tracking number and will pass  it on to you ...let me know when when you receive it and I can if you want run you through the build up .
All the best Chas
Re: C5 Motor dead?
« Reply #35 on: 29, November, 2014 - 23:10:10 »
No problem chas, I just wanted to make sure I reimburse you quickly for the posting and not let it sit as you and the other members have been great!   :)
Re: C5 Motor dead?
« Reply #36 on: 30, November, 2014 - 15:38:36 »
Hi there Adam no problem ..
Re: C5 Motor dead?
« Reply #37 on: 01, December, 2014 - 18:57:08 »
Hi there Adam tracking no sent to your email address
Bye and thanks Chas
Re: C5 Motor dead?
« Reply #38 on: 02, December, 2014 - 08:43:03 »
Hi there Adam lets wait till the rotor is in your hands.
Bye thanks Chas
Re: C5 Motor dead?
« Reply #39 on: 10, December, 2014 - 13:53:51 »
Chas,
Another question.  When I build the wiring harness should I place the fuse before or after the relay and what size fuse should be used?
Adam
Re: C5 Motor dead?
« Reply #40 on: 10, December, 2014 - 18:33:13 »
Hi there Adam will get back to you later got to go out won't be back till late
Ps if you can give me some idea of the wiring that you will be making ...And what will be connected to it
Re: C5 Motor dead?
« Reply #41 on: 11, December, 2014 - 18:08:57 »
chas,
I emailed you a pdf of my planned wiring setup.  Hopefully when the pdf is complete and finished, it will be a good resource for others that need to replace all factory wiring.
Adam
Re: C5 Motor dead?
« Reply #42 on: 11, December, 2014 - 19:26:59 »
Hi there Adam thanks for the message .
Regarding the wiring dia it looks great but I am no expert but I do have a mate that will check it out and I will get back to you ...
All the best Chas
Re: C5 Motor dead?
« Reply #43 on: 11, December, 2014 - 21:49:06 »
Chas,
I just received the armature!!!  wow...  that is what this unit is suppose to look like?  Chas, it's a thing of beauty...  Is there a certain way I should put it back together.  I am going to take this one slow to make sure we can get her back up and running the right way!
Adam
Re: C5 Motor dead?
« Reply #44 on: 11, December, 2014 - 22:09:07 »
That's great I was getting a bit worried..
What I can do is to make a small video on how to build the motor back up..in the mean time can you make sure that you have some grease and that the threads on the two long bolts are clean and a little greased ,and the rest of the parts are clean free from dirt and rust .
Also did you say that the brushes have been taken out ........????
Will get back to you ASAP all the best Chas ps don't forget the large thin bearing in the gearbox check that is turning free .
