Motor Armature bearings snapped off.
Started by reality404, 15, May, 2015 - 17:57:37
reality404
My motor armature bearings have snapped off. I'm guessing there is nothing I can do to fix it and will need find a new motor. Any advise on if I can fix it or finding a replacement motor would be helpful thanks.
KarlG
#1
It's a bit unclear when you write that the bearing has snapped off. A photo of the damage, or damaged part would help. Motor bearings are available, that is if it's just the bearing. Or is it that the bearing shaft has sheared?
reality404
Sorry I mean the shaft has snapped off. I did post some pictures of the damage but I can post more if you can't see it. Thanks
Hi- this is a fairly common failure point - you will indeed need a new armature assembly - if not a new motor - Would be worth contacting Chas as he may have some spares - Marty
