wiring problem
Started by scott, 09, June, 2009 - 22:43:46
scott
hello everyone  i have a problem with a loose connection on the pod plug block(red) control box end, one of the wires came out of its position so i put in back in but the pod only works if you wiggle the wire  so does anyone no if there is a special way to fix the wire back in perhaps soldering? any ideas ?i need to solve the problem so i can take bluebird 85 to brooklands saturday  cheers scott  :o
I used a computer connector on mine, I cut the wires ane fitted them one at a time (as they are all red). Then you could always buy a new loom from Adam.
