Author Topic: Battery Composition  (Read 4491 times)
Offline minimin
Battery Composition
« on: 16, June, 2009 - 18:31:03 »
Hi Everyone,
What type of battery has the C5? (The original type?) Is it lead acid?
Mark
Re: Battery Composition
« Reply #1 on: 16, June, 2009 - 19:08:51 »
Hi Mark,
Yes m8 its a lead acid type, the closest you can get (with out buying an original new one) is a leisure battery.
The closest size wise; is a battery called an 038 which you can (with a bit of a mod) can have the original battery top and carry straps (I use this)
here's some info about it
http://www.sinclairc5.com/facts/battery.htm
you can still buy them from here :- http://www.sinclair-research.co.uk/c5/parts.php
« Last Edit: 16, June, 2009 - 19:31:05 by Umpa »
