Chain Problem
Started by mike7201, 25, November, 2009 - 20:21:52
techytype
i had imagined about 3 hours to strip down, and 2 - 3 hours to re-assemble, why i grabbed frame to be able to clean and spray it up ready
been a lot of comment in here about separating the C5's handle bars stem, which seems to be a bit pia on most C5's due to rust issues :(
is there definitive way of doing this? or just use brute strength (and a lot of cussing  ;D).
regs
alan
I think it's more a luck thing with the handle bars - depending on the rust situation - must say I was lucky using the -one holding the front wheel and the other working the handle bars side to side method.
techytype
thanks Marty,
likely it will be after March time before i can attempt it.
i run a small business in alarms and IT, work is just piling in at the moment. i don't want to get it half done then be stuck without it available for the odd 'blast' for a few months  8).
regs
alan
mike7201
Hi all.  As luck would have it, I've managed to locate someone who's kindly offered to weld and repair my chassis so that I can begin using my C5 again.
However...  One or two questions which I haven't been able to find the answer to so easily this evening.
1.  What kind of metal is the chassis?
2.  Is there a step by step (photos and all) set of instructions on how to get to the chassis for welding?  I need to show the instructions to someone who's a welder by trade, but has never seen a C5 in his life.
Cheers,
Mike
Hi Mike - I had a friend weld one recently who used a TIG welder as he said this was the best one for the type of metal
mike7201
Thanks mate, but what metal is it?
Might be wrong but think it is a very thin (poss 1mm) mild steel (or fag paper !!!!!)
Yes indeed it is a pressed steel chassis.
To get to it you will need to do a full strip down. See link :
http://c5alive.co.uk/forum/index.php?topic=241.0
mike7201
Many thanks.   As well as waiting for someone to take a look at it, I managed to get it to a local car mechanic this morning and he said he could fix it for £30 all in.  He said that he'd need to move the control box though, so before I let him 'at it', is anyone able to assure me that if I follow C5 Martin's wiring instructions, the control box will be simple enough to remove then put back?
The mechanic said he could fix the chassis without a total strip down, but then he doesn't deal with C5's, so we'll see I guess.
It is quite easy to disconnect the control box - you need a 7mm & 8mm nut runner for the power connections the other connections are just a push fit. Should be no problem.
It is quite scary how easily the chassis bends as the metal is very thin but it is difficult to keep the box section intact. For £30 it's certainly worth a try. If it all goes wrong, given the damage yours already has, it's unlikely he could make it any worse.
In the end , even if you still end up having to do a chassis change you're not really any worse off for having tried the cheaper alternative  8)
mike7201
Thanks guys.
Will keep you posted.  Got my 30th birthday coming up in January, so we'll see what that brings!  My family and friends know I'm a C5 enthusiast, so perhaps if I don't manage to get my C5 fixed, I may be able to start saving for another one.
Cheers,
Mike
mike7201
Well, it's in the garage!  I pushed it to the garage, and they're treating it like any other road-going vehicle, in that they're giving it its own space in the repair shop, and they'll be working on it at a specified appointment time.
It's funny though.  I still love to see the looks on peoples faces when I take it somewhere.
Despite being a fully knowledgeable mechanic, I thought I should point out to the guy that the C5 shouldn't be reversed!  Nothing worse than having it fixed, only to find they pushed it backwards and destroyed the electrics.
sounds like you're making some progress, let us know how you get on.
mike7201
Done!!  8)
Just had a call to say the work is complete, and the C5 is awaiting collection.  I am guessing that if it's fixed, the chain should not slip any more, thus allowing me to pedal.
I'm rather excited about this.
I'll update when I can.
