Hi vis mask
Started by radiomarty, 21, December, 2009 - 21:43:58
Does anyone know the OD of tube used on the hi vis mask ? - I want to make something completely different for the pimping project.
Hi there the OD of the mast pole is 9mm IN SIDE DIA is 6mm LENGTH IS 59mm (also if the plastic coating has come of the mast poles the OD would be 8mm ) hope this helps
