Ebay C5 .. with engine
Started by minidaz, 11, February, 2010 - 09:19:25
minidaz
techytype
seem someone once had a great idea then let it slip away having done it seems the most part of the work needed.
could be fun to sort it out properly then give it a go up the test hill at brooklands the mini moto engines do seem to give a decent amount of power for size.
but i'd let challenger go up in front 1st - just in case it needed towing  ::)
regs
alan
Check out my petrol c5 videos on youtube under ID  JORDAN8ISH  BYE CHAS
I like the idea of a petrol powered C5 for a bit of fun, but would prefer more power with an electric motor. Fast and green !  :D
Petrol power goes against the very core of the C5 idea.  The future lies in a better gearbox and 24v. The C5 should remain an iconic electric vehicle, in my opinionated idea !  ;D
minidaz
Might be worth a gamble if the price doesn't go much higher, but knowing ebay, it'll probably shoot up in the last 10 minutes  :D
Daz
techytype
reckon it would be great fun, problem with it unless you have access to private land where can you ride it?
ok the 24 volt is a tad iligal, but you would be a bit unlucky to get knicked for using one unless acting the goat on it.
this C5 will make a fair old racket and a joy for the local beat copper to snap up and do you on.
so not something to buy in haste me thinks
oliver01379
I'm interested in this one!!!
I was plannign on getting it back to original C5 standard it has everything in place it jsut needs all of the electircs.
Any ideas where I can get this lot from guys?
To be honest if your wanting to put it back to stock, you would be better off buying a different one.
Umpa is right, you should consider the cost of all the missing components and weigh it up against the cost of buying one that needs nothing doing to it.
Some parts are getting rare now - which means prices are going up.
Well if anyone is interested  I'v started building another petrol engine c5 that will do 30 mph + and will have the braking system to stop it . so keep an eye on this site .  C5 s can also be used off road as well as on the road ..Chas
minidaz
Had a little bid when it got relisted, but it went over my price.
Will keep an eye out for yours Chas when it appears  :)
Daz
Chas - you're always welcome to advertise the c5 for sale on here when its ready.
Unlike Ebay, there's no fees attached with c5alive  8)
#13
Hi there thanks Karl I think I will probably take you up on that .But at the moment I 'v left the petrol
C5 on the back boiler and started building a 24volt / 900watt throttle controlled chain drive C5 Its just about  ready for testing on the road but will wait till next week and if it's ok will complete and fit the lights/ horn /trims a voltage monitor and a speed meter also connect the fan up and give it a good clean .Also fitted a set of cables to connect two battery's together and run the c5 with  foolproof connecting (will not work if you connect the leads the wrong way round and do no harm (relay and diode fitted with switch).
