Brand New (Some Original)Some used Sinclair C5 Spare Parts for Sale....Now!!
Started by C5 ENTHUSIAST + RESTORER, 22, April, 2010 - 16:37:57
Luke S
Quote from: C5 ENTHUSIAST + RESTORER on  22, March, 2013  - 08:56:59
Hi there luke sorry the Motor has not arrived it was posted on the 19th at 14:46 .It should be with you very soon .If it has not arrived by Monday let me know and I will get onto the post office ...
Sorry Chas I just wanted an idea when it would get here, just as I clicked send this morning it arrived. I did not have time to send another reply because I had to go to school  ::)
Ok no problem thanks take your time fitting it ...(What are you doing with old one)
Luke S
Quote from: C5 ENTHUSIAST + RESTORER on  22, March, 2013  - 18:38:38
Well I am hopping to re-grease the old motor and keep it for a 'backup'
I am hopping to get the new motor on the C5 before the Crawly run on the 14th of April
Luke S
HI Chas - I need a set of frame plugs to hold the control box to the chassis - can you email details please Regards Marty
Hi there Marty I on holiday and will not be be back until the 24 of this month ,so in the mean time if you could  email me your full  address I will post you a couple ASAP
.Bye for now Chas
aceofhearts
Hi Chas,
Do you still have the thin gearbox bearing? I am also after a secondhand motor (gearbox not needed if you have the bearing) as i really can't afford £150 for a new one :(
Hi regarding the large thin bearing I will let you know also have you seen the motor on eBay ...cheaper than a new one
aceofhearts
Hi Chas,
Against all the odds i got the motor stripped and running last night! I will post a couple of pictures of how it was (the C5 in question was found in a bog!). I managed to find some motor bearings to replace the wrecked ones. I have got some gearbox bearings from a supplier i know from work. Only thing is the outer belt drive looks quite brittle so I will have to see how it goes. I will email the guy on eBay though as it has just ended without bids.
Ariablutron98
Hi chas it's me got any spair body's that need work for a cheap price? Thanks
