new or old wiring???
Started by hammy, 03, August, 2010 - 19:47:54
hammy
So my c5 is now semi operational...pedal only. What begun as a buy to sell item has now turned into a great project...i can't keep the kids out of it!!
well, ive now got a decision to make...do i keep the old wiring or go for new?
I dont have a battery or battery top, just a key box on either side and they look corroded. The control box looks clean.
So do i try and clean and service these parts or start from scratch with new wiring and new battery.
Advice welcome...
plumber
hi there can you put some pictures up so we can see?...i still like the old key switch myself...where do you live?
many thanks the plumber... ;D
coverman
Without a battery top it would be trickier to use the keyswitch. It does have the advantage of the battery isolation button though. If you can get a battery top it is then easy to use a type 049 45Ah battery which can be found quite cheaply.
