had a try with one of these betteries
Started by marra, 31, August, 2010 - 19:07:16
marra
bought one of these from flee-bay. I got a battery top given off a mush when i bought a pod from him, so as it cost me nothing I chopped and cropped it to fit. Charged about 5 times and doing good. Only seem to be getting about 15 miles though  :-\ . According to the C5 manual on a battery half this size I should be getting that anyway. Oh well, for what I paid it isnt bad. Marra
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140438531116&ru=http%3A%2F%2Fshop.ebay.co.uk%3A80%2F%3F_from%3DR40%26_trksid%3Dp4712.m570.l1313%26_nkw%3D140438531116%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1
Never mind the manual i'm thinking 15miles is very good - would be interesting to know how it keeps performing over time -Thanks for that.
marra
So 15 miles on 76 ah is good, I was looking at getting a 110 ah  ;D ... pretty heavy though  :( May get another one of these .... more miles then.
MikeDX
Quote from: marra on  31, August, 2010  - 19:44:37
What's the weight of that Marra? Can you bung it on the scales for us?
The advert says.... "Weight approx 27.5 Kg"  :-*
marra
Quote from: MikeDX on  31, August, 2010  - 21:46:22
Mine showing 29.5 - 30 kg.
That is quite heavy, doubt you could run a 24v using two of those as I'd be worried about the chassis.
Not a problem though if you're sticking with 12v and carrying just the one battery.
marra
Quote from: BooBoo on  01, September, 2010  - 07:52:59
You are right, If I go 24 then prob just buy a couple of car lead acid ones like recommended on earlier threads. This one seems to be good as its lighter than 2 x 36/38 ah ones that I have seen, but getting the same ah's.
coverman
The advertised weight for the battery is obviously prior to charging.It weighs significantly more when full of electricity!!!!.
coverman
Actually, my 45Ah car battery weighs only 12.5Kg.
marra
They sound to be better then, what type are they ? Only thing with that I would have to buy another charger. suppose they cheap enough anyway.
Rickvalet
Hi, I splashed out and bought a Ping battery off Ebay. Ping builds them to your spec and they are Lifepo4.
Battery spec
Lifepo4
12v
40 Ah
Weight 5kg!!!!
The Results?
Well I get about thirty miles from a charge and you really notice the 10kg weight saving. I Pulled the guts out of the Oldham battery and put the new one inside so it looks original and retains key.
These new Ping batteries really are superb.They cost £350, but will outlast the life of a lead acid more than eight times over.    :)
mike7201
That's exactly what I was thinking!   :o  :o  :o  :o  :o
A bit like the printer being cheaper than the ink.  In this case, you could get another C5 for £350!!
techytype
i was thinking more about doing 30 miles in a C5  :o, what 'numb bum' time that would be  ;D
Alan
